DSL Slow Speed Problem (ENG)
rafalski102
Hello.
I live in Germany in Schwabisch Hall. I bought Red Internet & Telefon 100 DSL Package, and I have big problems with DSL Connection. It is very slow, i'm getting 20-50kb/s in download (sometimes i have 2 MB/s for couple of seconds). At the first days of internet all seems to work fine - i was getting 7-10 MB/s and have high ping but that wasn't for me such a big problem. After a week, the internet was getting slower and slower, i was trying to reset router etc. And I'm stuck at horrible 20kb/s with 20 euro to pay for 100 MBit/s internet. Please answer asap.
Dear Rafal
5 Antworten 5
Jens-K
Ex-Moderator:in
Ex-Moderator:in
Hi rafalksi102,
welcome to the Vodafone Community!
Here you can check your bandwidth: http://www.speedcheck.vodafone.de
While doing the speedchecks use a connection via LAN cable and connect your device directly to the modem.
Do not use WIFI and make sure that there are no streams or downloads running.
Do at least 3 speedchecks during different daytimes and post the results here. Thank you.
Regards,
Jens
Hi again,
I've done what you want, and i'm getting pretty interesting results, i've got for 2 days a internet with 5MBit/s download and 30MBit/s upload. Especially this evening on 9:30 pm download speed 95MBit/s for 9 MINUTES. What are you thinking about?
Jens-K
Ex-Moderator:in
Ex-Moderator:in
Hi rafalski102,
this doesn't look like an overload to me.
Please have a look into your modem log if you can see several reconnects or timeouts.
Check all cables and the phone socket for obvious damages.
Also do a modem reset and activate it using your Modem-Installations-Code.
Regards,
Jens
I've checked all cables, checked if maybe ethernet cable is bad but this didn't affect to the result. I did factory reset (again with activation) after second internet speed test and as you see that didn't help me.
Thanks Rafalski102
Ps: check the logs
Jens-K
Ex-Moderator:in
Ex-Moderator:in
Hi rafalski102,
send me a private message. Click on my avatar -> Diesem Benutzer eine private Nachricht senden.
I need your name, your customer number and your mobile phone number.
Regards,
Jens
