am 18.10.2018 21:47
am 30.12.2018 14:59
Hello fotoramic,
a new technician assignment's out. 🙂
Regards
Jens
am 19.10.2018 00:11
am 21.10.2018 00:27
am 23.10.2018 17:55
Hi fotoramic,
we're already talking about the contract you just moved to or another one? There is currently a 200er bandwidth available. How is the connection via LAN?
Best regards
Lars
am 23.10.2018 20:43
am 29.10.2018 15:57
Hi fotoramic,
the modem supports Gigabit through LAN. It seems like the connected Hardware doesn't or the connected cable doesn't. Did you replace that for a test?
There are over 40 WiFis in your direct neighbourhood. That's the reason why there is a bad connection with 2,4GHz. You should use 5GHz in this case.
Kind regards
am 29.10.2018 16:14
am 01.11.2018 15:27
Hi fotoramic,
there some WiFis with same SSID, f.e. the Hotspots. From your experience we should replace the router for free. Is that okay for you?
Kind regards
am 01.11.2018 16:18
am 07.11.2018 09:03
Hi fotoramic,
at this moment there are exactly 26 WiFis (2,4 and 5GHz combined). There were 44 on the previous check. Your modem alone emits 4 WiFis ![]()
However when we did replace the modem in the past an the WiFi did not change to better quality, there is nothing we can do at this point. It is a standard-modem with regular performance. If you want a better WiFi you can use your own router instead of the given one or you can use a router behind the bridged cable-router as WiFi-accesspoint.
Kind regards
