am 18.10.2018 21:47
am 09.11.2018 01:35
am 14.11.2018 16:22
Hi fotoramic,
you were talking about the bandwidth through WiFi all the time an not about disconnects ![]()
I'm not sure what's the main problem. So we replaced your modem and it shows the exact same behaviour like the previous one. The connection looks good. In my opinon the reason is the used device. Did you check a different one?
Kind regards
am 20.11.2018 16:58
am 20.11.2018 16:59
am 26.11.2018 08:35
Hello fotoramic,
how many neighboring foreign WLAN networks are there in your area? If the WLAN connection breaks down, does it break off simultaneously on all devices in the household? On which frequencies are you currently connected?
Best regards Fred
am 05.12.2018 17:33
am 11.12.2018 13:26
Hello fotoramic,
how you determine how many WLAN networks there are in the neighbourhood is quite simple 😉 You go to IPhone under Settings and then WLAN. And then you count all receivable networks except yours. Maybe they influence the reception.
Best regards Fred
am 12.12.2018 08:13
am 16.12.2018 14:48
Hello fotoramic,
that's a rather unusual problem. I made a task for an internal specialists department with all the information you gave us, maybe they have an idea what might be the source of that.
Kind regards
am 17.12.2018 08:47
