WiFi Repeatedly Disconnecting
SV3
I have a GigaZuhause 1000 Kabel connection. For the past 2 days, WiFi has been disconnecting and reconnecting after a while, every half hour. We have also tried the Factory reset option of the Router. But no luck. The problem still persists. Any suggestions on what to do, other than contacting the customer care?
Genwyn
Hello!
It's best to contact us, especially if there is a hardware-problem with the Router.
You can reach us directly via WhatsApp https://vod.af/VodafoneWhatsAppHilfe
LG Genwyn
