am 04.02.2020 17:20
Hello, I am existing customer of Vodafone Kable internet at my home as well as my mobile provider.
Its been 2 months, my home wifi internet started, but since first week, I am seeing speed of internet is very very slow.
My plan for Kabel internet is - Download speed 100MB and Upload speed 50 MB
But when I did speed test from vodafone as well as other sites at my home wifi - the what I gets is -
Download - I am getting in between 21 to 35 MB and
for upload - I am getting speed around 6 to 7 MB
This is way slo than what my plan is, its realyl frustrating to see slow internet at home, its take 2-3 minutes to load Gmail account, that waiting circle keeps spinning for Youtube for mins to load one video and same happes with facebook updates.
Can someone from Kable internet customer service help me here please ?
Thanks
Atul
am 18.02.2020 16:56
Hello @Manu , Thank you for explanantion on the image.
I did the restart of the router almost once a week but still never helps, but if you suggest, I will try to do it again.
Yes I always get different values and never gets actual activated product speed which is 100 Mb and 50Mb.
I tried using LAN cable and still the speed is low as I mentioned.
I received a call from technician in last week about the ticket opened for this issue, and he just gave me suggestion to check the speed using LAN cable and before knowing the results he closed the ticket, not sure why.
He mentioned that the LAN might give speed and Wifi might have issues, but with LAN also I am not getting my desired speed of 100 Mb and 50Mb.
For moment even if we consider that LAN gives speed (which is not case currently), even then also issue remains there like - what is the use of wifi internet connection I took in my home, If I am not going to connect my laptop all the time to router using LAN or how can I connect my TV and my mobile phones to internet network, which is very slow.
It needs to have my requested or subscribed speed to connect remotely using WIFI and not LAN cable.
I will let you know speed stats again after restarting the router today.
Thank you
Atul
am 20.02.2020 09:26
Hi Atul,
I really don´t know, why the colleague, who called you, did not wait, until you tested via LAN....
Your router is online for about 16 days. Please test the resart an make a screenshot of a speedtest via LAN.
I expect you answer.
Best Regards, Manu
am 22.03.2020 16:26
Hello, @Manu
Apologies for delayed reply. I was busy in some office work so could not get back to you.
Recently due to CORONA we started working from home office and I am facing real nightmare on this front due to the internet speed issue I am facing.
I tried to restart router several times after you suggested and also tried to measure the speed using LAN cable.
I notied with LAN Cable also the speed is very very low - please find attached image when I did LAN speed test.
Speed test with LAN -
Download - 41 Mbps
Updated is good speed - 50 Mbps - as expected
I am really getting depressed with this internet issue @Manu - please please pleas help me in getting this solved.
can you please raise a ticket for any technicial who can visit to my address and check what is this issue is please please please ...
I really want to solve this, I cannot work, I cannot talk with family members etc.
can yuo please help me.
Please let me know if you need anything from my side.
Best
Atul
am 24.03.2020 16:01
Hello atulPatil,
I can send a technician over to you. However, if he finds out that there is no malfunction, the malfunction only occurs via W-Lan or the malfunction is caused by your cabling or end devices, the service will be charged with 99,50 €.
If this is ok for you, please send me a PN with your mobile phone number and let me know if there are any symptoms of Covid 19 in your household.
Best regards, Martin
