Internet connection-Problem
Sindhu
Hello,
Since today morning i have problem with my internet connection.It is Red internet& Phone 50 DSL. The lights are green for the power and WLAN, but still i could not conect. In the Fritz account, it says "Anmeldung beim Internetanbieter ist fehlgeschlagen-Terminated LCP" Any help or suggestions on this would be helpful. Thanks.
Jens-K
Ex-Moderator:in
Ex-Moderator:in
Hi Sindhu,
welcome to the Vodafone Community!
Here you can check if your there is a known fault: Netz-Experten. If not you can do our net expert check there.
In many cases it helps to restart the modem by switching it off for a couple of minutes and siwtching it on again.
Also please check all cables and sockets.
Regards,
Jens
