Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Vodafone CableMax 1000 is disconnecting every 5-15 minutes
AlexeyK
Hallo!
I live in Berlin and have Vodafone CableMax 1000 internet with Vodafone Station router. It worked more or less well for about 2 months, but now it disconnects every 5-15 minutes. WiFi connection is still there, but no internet. Internet and telefone LEDs become red, then blink white for several minutes, then everything is OK for the same 5-15 minutes, then the same situation repeats.
I have tried to restart the router and completely reset it  several times, but it did not help.
The only suspicious thing I found in the Admin UI is that on the DOCSIS status page the 9 / OFDMA channel is always in the FAILURE state (see the attached screenshot). Not sure it's related, but I'm pretty sure it was SUCCESS, when I first got my router working.
How can I get this fixed?
Hello AlexeyK,
sorry to have kept you waiting :/. Are there disconnects via ethernet connection as well? Did you replace the coaxial cable already? If possible please try a different multimedia socket as well. If that doesn't help please contact us on one of our service channels.
Kind regards,
