Cable Modem is not working
HI7
Youngster
Youngster
Cable modem stopped working suddenly.  The internet lamp (red) continues blinking.  I have restarted the modem couple of times but no change at all.  Can you please arrange technician?
2 Antworten 2
reneromann
The fastest way is to call the technical hotline, even though this one is only available in German.
It may take multiple days until a moderator reads this message and can get in contact with you to make an appointment for a technician.
ERFD
Ex-Moderator:in
Ex-Moderator:in
Hello HI7,
Were you able to place the problem via the hotline and were you offered a solution? Otherwise, we will be happy to look into the problem. Can you please answer these points for a better overview?
Regards Fred
