Very low speed
Artjom
Good day,
I have a problem with my internet - extremely low speed. My tariff is Red internet & phone Young 200. My internet speed must be 200 Mbps. But i have the speed from 1Mbps-15Mbps.
Edit: @Artjom thread moved to right board
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Artjom,
the technician is assigned and will call you to make an appointment. Please contact us again and let us know if everything worked out.
Kind regards
7 Antworten 7
SebastianSe
Ex-Moderator:in
Ex-Moderator:in
Hello Artjom,
I would like to help you.
Please tell me, if the speed is that low all the time or only sporadically. Are you connected via cable or wifi?
Kind regards,
Sebastian
Hello Sebastian,
I'm connected through Wi-Fi and Cable and i have the same speed for the both types of connection.
Speed, almost all the time, is low
Ex-Moderator:in
Ex-Moderator:in
Hi @Artjom,
i would like to check your connection, could you send me please your customerdata (customernumber, your name and your adress) via private message?
Thanks & regards
Ex-Moderator:in
Ex-Moderator:in
Hey @Artjom,
thanks for your message - well, i would like to send you a technician because your modem got some problems - could you please send me a mobilenumber where the technician could reach you?
Thanks & regards
Artjom
Yes, sure. I've sent private message with my phone
pRo-Marco
Ex-Moderator:in
Ex-Moderator:in
Hi Artjom,
Kind regards
The technician visited me and solved the problem. Many thanks!
