am
22.03.2018
13:42
- zuletzt bearbeitet am
22.03.2018
13:55
von
Lars
Good day,
I have a problem with my internet - extremely low speed. My tariff is Red internet & phone Young 200. My internet speed must be 200 Mbps. But i have the speed from 1Mbps-15Mbps.
Edit: @Artjom thread moved to right board
am 23.04.2018 08:52
Hi Artjom,
the technician is assigned and will call you to make an appointment. Please contact us again and let us know if everything worked out.
Kind regards
am 27.03.2018 14:48
Hello Artjom,
I would like to help you.
Please tell me, if the speed is that low all the time or only sporadically. Are you connected via cable or wifi?
Kind regards,
Sebastian
am 12.04.2018 15:36
Hello Sebastian,
I'm connected through Wi-Fi and Cable and i have the same speed for the both types of connection.
Speed, almost all the time, is low
am 16.04.2018 09:56
Hi @Artjom,
i would like to check your connection, could you send me please your customerdata (customernumber, your name and your adress) via private message?
Thanks & regards
am 19.04.2018 10:53
Hey @Artjom,
thanks for your message - well, i would like to send you a technician because your modem got some problems - could you please send me a mobilenumber where the technician could reach you?
Thanks & regards
am 19.04.2018 11:01
Yes, sure. I've sent private message with my phone
am 23.04.2018 08:52
Hi Artjom,
Kind regards
am 24.04.2018 10:35
The technician visited me and solved the problem. Many thanks!
