am 09.12.2019 18:06
Hello,
I have cable and am recently upgraded from 100Mbps to 1Gbps, however, I am still only receiving 100Mbps. I contacted tech support, they told me to restart. Upon following their instructions, I am still only receiving 100Mbps.
Speedtest link:
https://www.nperf.com/r/3227465729836537-XwVCccGx
am 11.12.2019 11:05
Hello MattV,
is the new tariff active according to the customer portal? Did you test through LAN? Do you get this speed each time of the day, so in the morning as well?
Kind regards
am 11.12.2019 19:14
Hello Claudia,
The tariff is active according to the portal, I did test through wired LAN and yes I get this speed all the time. I did upgrade from 100Mbps to 1000Mbps which may explain why I am still receiving 100Mbps.
am 13.12.2019 09:13
Hello MattV,
okay, I'd like to check your access to find out why your speed is so slow. Please send me a private message with your address, date of birth and the customer number. Leave a short reply in this thread after you sent the details.
Kind regards
am 15.12.2019 20:07
I sent the information
am 17.12.2019 11:33
Hello MattV,
with which device do you test? A device is connected to the LAN 1, which can only achieve a maximum of 100Mbit. Do you test with it?
Best regards
Moni
am 19.12.2019 10:20
I am using my own additional router to extend my network to the second floor of my house, it says it supports 10/100/1000. My PC is hardwired to that device.
am 19.12.2019 15:30
am 20.12.2019 15:25
Hello MattV
so you made the second speedtest while your PC was directly connected to our modem via LAN? Please use the speedtest in our customer portal and log in first, in that case the results are saved and we can check them.
Kind regards,
am 29.12.2019 12:20
Hello,
I have done several tests, while logged in on 29 Dec 2019. I can see the speed test bounce above 100Mbps for a split second then it drops back down to around 90. I have done this while on WiFi, LAN (both directly into your router and mine) the results are the same.
