am 02.07.2019 01:40
Hello,
I am currently subscribing to Red Internet & Phone Young's 200 Cable and Internet have been perfectly fine with a few exceptions.
INTERNET LED wants to start flashing red. I've done a power reset, factory reset of the router, and used different cables. It just happens randomly comes back online as if nothing has happened. The internet does not provide a connection, but the internet does not work, it shows as offline.
The overview page shows that DOCSIS is offline.
No IPv4 address is setup
And the DOCSIS status page shows:
Downstream:
Channel ID | Channel Type | Frequency (MHz) | Modulation | Rx. Power (dBmV) | SNR/MER (dB) | Lock Status
33 | OFDM | 167~234 | 256QAM | 0.6 | 35 | YES
0 | OFDM | 0~0 | UNSUPPORTED | 0.0 | 0 | NO
0 | SC-QAM | | UNKNOWN | | NO
Upstream
2 | SC-QAM | 52 | 64QAM | 46.3 | SUCCESS
General Information:
- Router / Modem: Vodafone TG3442DE
- Router firmware version: AR01.01.117.01_091718_70.PC20.10
- Hardware Version: 7
I'm just looking for some feedback or help because it's getting real annoying with these random disconnects.
am 02.07.2019 20:24
Hello, BigFella,
Please send us your customer number, address and date of birth by private message. We will be happy to take a look at your connection. Write to us here when you have sent the data.
Best regards Fred
am 02.07.2019 22:15
Hello Fred,
I have sent you a private message with the requested information. Thanks!
am 03.07.2019 17:42
Hello, BigFella,
there are a lot of timeouts visible on the modem. This is caused by an error rate in the downstream. This has to be checked by a technician on site. Is the supplied antenna cable connected or is a separate one used?
Best regards Fred
am 03.07.2019 22:36
am 05.07.2019 07:46
Hello, BigFella,
is this the original cable or a private cable from the modem to the antenna socket?
Best regards Fred
am 05.07.2019 12:42
am 06.07.2019 19:03
Hi BigFella,
no, you have chosen the right socket, no worries.
I don't think the problems are related to certain actions on the Internet. The line itself has problems.
I'll send a technician to check it out on site. The colleagues contact you by phone to make an appointment.
Many greetings, Manu
