am 27.04.2022 12:17
For over a month now, I loose internet access everyday in the afternoon. It happens between 11:30 AM to 14:30PM, and I need to restart the router to get it working again.
I have already tried leaving the router turned off for a while, resetting it, but it does not fix the problem. The router is model Compal CH7466CE.
Please help!
Thanks
am 27.04.2022 18:22
Hello Cust38,
I would be happy to take a look at the line. Please send me a PN with your customer data (name, address, customer number and date of birth).
Please contact me again when you have sent me the data.
Best regards
Moni
am 27.04.2022 21:23
Hi Moni,
Thank you for your reply. I've sent you the information as Personal Message.
Best,
am 28.04.2022 11:10
Hello,
we also need the date of birth. Your mediator is also welcome to contact us directly.
Greetings
28.04.2022 14:10 - bearbeitet 28.04.2022 14:17
Mein Geburtstag: <redacted>
mit besten Grüßen
Igor SchotskI
am 28.04.2022 15:44
The router changes frequencies and the error rate directly at the port is too high here.
A technician should take a look at this on site.
Do you agree?
Then I just need the answers to three questions.
1. under which telephone number can the technician reach you?
2. it is important that the technician has access to the house system. Can you ensure this?
3. did people in your household experience symptoms in the last 14 days that could be related to Covid-19?
The service is also free of charge for you. Only if the technician does not find anyone at the agreed time, the fault is in your own cabling between router and antenna socket or in your own equipment, or if he cannot gain access, we will charge 99.50 € for the service.
Greetings
am 30.04.2022 11:02
Hello Cust38,
thank you. I made the task for the technician. You should get a call from the colleagues in the next few days.
Kind regards,
am 06.05.2022 10:43
The technician visited today, and said the issue has been fixed. Unfortunately, the disconnection happened again after the visit.
I dont think problem is resolved.
Best,
am 08.05.2022 09:01
Hello Cust38,
what did the technician do exactly? The signal data is slightly out of range. You can reopen the ticket ***263/22 in the next few days and the colleagues have a look at that again, just check the email we sent you on Friday.
Kind regards,
