16.02.2022 23:29 - bearbeitet 16.02.2022 23:35
Hello,
Since the starting of February, I am having constant high pings everywhere and a lot of packet loss, I was already assigned a ticket, but there seems to be no progress on it.
am 21.02.2022 11:17
Hello GauthamR,
Welcome to the Community:)
The target 104. 160. 141. 3 does not answer over any network and leaves 100% packet loss. Obviously, it doesn’t want to be ping. Can you please leave a full test of an achievable target here? Complete does not mean the last 6 HoPs.
Greetings Fred
21.02.2022 11:30 - bearbeitet 21.02.2022 11:43
Hello @ERFD
Thank you for your response, I am not too aware of the pingplotter, but here are couple of screenshots with google.com, but the problem I have is, I have huge ping spikes & packet loss for almost every server, it doesn't matter which game I play, which meeting I attend online, it's all the same spikes and packet loss that is giving me troubles, this has been happening a lot since the last outage. I really need help with this, as its disrupting my work from home quite a bit. Please help me out
21.02.2022 19:42 - bearbeitet 21.02.2022 19:45
Also, I just wanted to update that along with the spike and high pings, I am also having constant disconnections, even though the LEDs are stable white, I have to restart my router again and again. 😞
am 23.02.2022 20:40
Hi @GauthamR,
i would like to send you a technician, you got so much timeouts (thats not normal 😞 ). In that case, the service is also free of charge for you. Only if the technician does not meet anyone at the agreed time and cannot gain access, will we charge €99.50 for the service.
Do you agree with the technician's intervention and can you provide access to the house? What is the best number to call to make an appointment?
Regarding COVID-19: Are you in quarantine or are there symptoms in your household that indicate COVID-19?
Regards
am 23.02.2022 21:21
Hello @Tobias
Thank you for your response, I would like to understand the service better, what kind of house access do they require? Is it Kellar access or just apartment access? Could you please elaborate?
If its just the apartment access, then it sounds good to me, should I PM you my phone number?
No, I do not have any covid symptoms.
Looking forward to your response.
Best,
Gautham
am 25.02.2022 19:46
Hello Gautham,
we need both access. The technician have a look at the cellar, where is the house system and in your apartment, to check if anything ok.
Can you give it to an appointment?
Is you number xxx09 right? If yes, we need no other number.
Regards
Jens
25.02.2022 20:05 - bearbeitet 25.02.2022 20:06
Hello @Jens,
Thank you for your response. Ok understood, yes I suppose I can ask the hausmeister to keep the cellar open during the appointment date / time, when can you give me the appointment?
Yes, that's the number.
Best,
Gautham
am 27.02.2022 19:28
Hello GauthamR,
I have instructed the technician. You will be called to make an appointment.
Greetings Moni
am 27.02.2022 19:53
Hello @Moni_GK
Thank you, I received an email, and I booked an appointment via the portal itself, hope that should be enough?
I also wanted to point out that, along with the existing issue, my internet speed itself has degraded for few days now, here is the screenshot.
This is from https://speedtest.vodafone.de/ and you can see how the incoming data to the router itself is only 365Mbits 😞
Best,
GauthamR
