Problem about the Easybox 804
alperen07
Hello,
I have a EasyBox 804 router and DSL internet connection. From yesterday, my connection was cut and also my local wifi network disappeared. I check the router and leds above router all is off (not red or green). Red led below the router is blinking. I even couldn't connect router page with the cable. I unplug the power cable and waited 3 minutes, problem was still the same. I tried to hard-reset but after pressing button anything happened in router. After 10 minutes, router started to work and resetted. I enter my MIC code and re-configured router, then internet works for me about 5 min. and after again my local network disappeared. I did the same steps maybe more than 5 times but results still the same. I can't speak German and Vodafone doesn't have English hotline. I regret to select EasyBox 804 router. If problem in the router, I would like to switch urgently. Could you help me to solve this issue urgently because for my work, I need to have an internet connection.
Best Regards
Alperen
Andre
Hey alperen07,
I'm sorry to hear that your landline is not working.
If all devices loose the connection to the router, this feels like a defect of the easybox.
I've checked your customeraccount . It looks like you've already openend a technical ticket with an appointment onsite on the 11th 14-20 o'clock.
Please wait for the technician appointment for further diagnostics.
Cheers,
Andre
