From physical sim card changes to esim card of CallYa
HtaoDE
Hallo. I am an old customer of pre-paid CallYa product. Currently, I use the physical nano sim card, but I need to use a dual sim card. And I need to change one of the sims to esim. I saw the news that Vodafone start to provide esim service to prepaid customer since October 2022. I want to ask, as a prepaid customer, how can I change my sim to the esim? Do I need to pay for the fee for the exchanging card process? Thank you.
AnnikaP
Hi @HtaoDE,
you are wollcome to change yor SIM-Card in a eSIM. The costs are a one-off fee of 5€.
For the exchange you have following contact options: Euer Kontakt zu Vodafone - Vodafone Community
Best regards,
AnnikaP
Netz-Assistent How To Hilfe !
#bleibtgesund
if my physical sim card was broken or lost, do I need to pay for the new one? And if I want to change my esim to a physical sim card, do I need to pay for it as well?  if I activate the esim card, for the previous physical one, can I also use it but not simultaneously?  if I buy a new number, I choose esim. later, I change it to a physical sim. do I need to pay for it?
thank you!
AnnikaP
Hi @HtaoDE,
a SIM card exchange always costs 5€, unless the card is defective.
You can either use a physical SIm card or an eSIM. Both are not possible. If you have an eSIM and then you need a physical SIM card again, than this must be manufactured separately.
Regards,
AnnikaP
#bleibtgesund
