am 05.09.2023 18:19
am 05.09.2023 21:49
Look in your order confirmation, there the possible tariffs and the prices are listed. You will also find the telephone number there, under which you can have the change made without extending the contract period up to the end of the 6th month of the contract (only in German).
If you need support in English, use the Vodafone Service channel on Facebook or Twitter (now named X). There you'll get support even in english.
am 05.09.2023 21:49
am 11.09.2023 18:39
Since the solution has been marked here, I'll close now. If you have any questions or concerns again, just start a new thread in the correct board. Please note, however, that direct support is no longer possible here. It is best to read this article.
