am
14.02.2020
14:45
- zuletzt bearbeitet am
17.02.2020
12:19
von
Jens-K
Dear all
recently, i got device for Vodafone for WIFI.
and below is my problem.
1, when i try to log in to gateway for installing internet, password about gaterway is invalid.
so, can i get new password about gateway?
2. if is ucceed to log in gateway i need installation cost for activating my internet.
so, can i get new password about installation code?
i will realy appreciate if you reply my serious problem and inquiry.
Thanks in advance.
Edit: Moved to the right board.
@EUCwordwide Edit 2: Moved from DSL to Kabel.
15.02.2020 11:49 - bearbeitet 17.02.2020 12:23
Hi EUCwordwide,
welcome to the Vodafone Community!
Which modem and which type of connection do you use (DSL or cable)?
If you are using DSL, all you need to do is activating your modem using the Modem-Installations-Code. You will find it in our welcome letter (usually sent via e-mail)
If you're using an EasyBox open https://www.easy.box if you're using a FritzBox open https://www.fritz.box in your browser. You will then be guided through the installation process.
Regards,
Jens
am
16.02.2020
21:51
17.02.2020
12:18
von
Jens-K
Dears
Thank you for your reply.
But real problem is that my password about louter is still invalid.
My customer number is xxx.
I appreciate if you check on the basis of my customer number.
Thank you
@EUCwordwide Edit: Customer number deleted. Please do not post personal data in public.
am 18.02.2020 14:01
Hi EUCwordwide,
did you connect your router with all the cables so that it can connect to our network?
Is any LED glowing?
Best Regards, Manu
