am 07.07.2018 13:33
Hello,
I'ts been a month since i switched to Vodafone Internet , My problem is whenever i use on my Phone the wifi 5Ghz the wifi keeps dropping and i need to reconnect again after a few minutes It's really strange because i disabled 2.4ghz wifi I use ethernet cable on my laptop and the internet is fine and doesn't drop Is this happening only to me or what? ty for help
07.07.2018 14:00 - bearbeitet 07.07.2018 14:01
Important: The 5GHz frequency band is not supported by all wlan devices. If there are any questions left contact the manufacturer of the product.
source: https://kabel.vodafone.de/hilfe_und_service/geraete/wlan_kabelrouter_sagem
am 07.07.2018 14:29
I'm using on my Iphone 7 , Iphone 8 , Samsung Tablet so on all of them keeps dropping ? and what's the point on having the 2.4ghz enabled when my internet speed is 40Mbps and i have Vodafone 400.
am 07.07.2018 19:07
Please keep in mind that due to regulations of the usage of the 5 GHz frequency band, all routers have to support DFS (Dynamic Frequency Selection). In case of a radar detection, they have to switch off the 5 GHz network at all (or switch to a frequency where there is no radar signal).
This might happen excessively next to air ports - and then the devices might drop out of the WLAN...
am 09.07.2018 16:01
so probably we cant do that much in that case, probably it isnt a defect.. 😞
If you want i could check your connection, please send me your customerdata (customernumber, name, adress) via private message.
Regards
am 23.07.2018 23:42
I'm trying to send u a PM but it's not working is there a way to send u an e-mail
thanks! 🙂
am 23.07.2018 23:46
I'm not sure what was the problem but somehow it worked.
I sent u the PM.
Cheers!
am 25.07.2018 11:53
am 25.07.2018 21:23
Hi Mevlan01,
Your connection must be checked by a technician on site, because he has only one instead of 4 upstreams. Do you agree to a technician assignment and can you provide access to the house system?
Regards
Wallace
am 25.07.2018 21:27
