Sagecom Fast 5460 false reporting network situation
medicol
App-Professor
App-Professor
Hello, I have a Sagecom Fast 5460
in past time all ok.
Now:
- it reports WiFi off even if is on and mobile phones and computer connected
- it reports nothing connected via WLAN even if there is PC, IPTV box, Satreceiver, Powerlines
- it is not possible configure port forwarding because I cannot read MAC of PC
Can anybody help?
Hello medicol,
I made a task for the new router, you should get an e mail with the tracking code as soon as the device is sent. It may take some days due to the upcoming holidays. The address for the old device is
Vodafone Kabel Deutschland GmbH
c/o DHL Paket
Am Tower 222
90475 Nürnberg
Kind regards
29 Antworten 29
Moni_GK
Hello medicol,
Have you changed anything? If yes, what? If not, please reset the router.
Best regards
Moni
Hello Moni,
no, I changed nothing, absolutely nothing.
Luca
Moni, I forgot to mention that I have already done power off / power on but situation did not change
did you try a factory reset? Or just a powerreset?
Regards
No, I only tried power reset.
Should I try wih factory reset?
If yes could you please give me the procedure?
Firmware version is 6.1.2.31-IMS-KDG
please notice that I am writing you via Wifi and telephone is ok so practically what modem is reporting is totally wrong
sorry for the late response. You could initiate the factoryreset by pressing the "reset" button for 30 seconds, you can find the button on the backside. And yeah, looks like its a failure when you can write via mobilehpone 😄
Regards
