fritzbox + synology NAS setup issue, Thanks in advance
eric_xp
Dear all,
Pls. Share your experience or suggestions for my issue, thanks in advance!
my network and equipment info:
ISP: Vodafone Cabel *250M
Router: FritzBox 6660
NAS: synology 920+
Problem:
Due to Vodafone cable is using: DS-Lite tunnel, so no Public IP4 address.
VPN & DDNS can not work as before. (now, NAS- Synology works well, but use Synology/quick-connect , other DDNS no work?
in the Router setup platform, where is the Port Forwarding configuration interface? (Not found it. or whether no the interface?)
Whether have a solution to make my VPN and DDNS work?
Thanks again...
Kieferer
Host-Legende
Host-Legende
Sollte mit ipv6 gehen
Ansonsten Dual Stack buchen.
