Wie kann ich das Telefon nach dem Wechsel des Routers zur Fritzbox wieder anschließen?
Leside
Forum-Checker
Forum-Checker
Hello.
I have switched the router from Vodafone Station to the FritzBox 6690. Internet and television are working fine now, but the landline phone is not working.
How do I reconnect my phone number and phone device?
Thanks in advance for tips.
2 Antworten 2
Is the 6690 a private or rental box?
reneromann
If it is a rental box: Just plug your phone into the Tel1 port from the FritzBox - same as you did with the Vodafone station. You may anyhow adjust the number assignment within the phone configuration page of the FritzBox.
If it is a retail box, you still need to plug your phone into the Tel1 port from the FritzBox, but you will also have to enter the VoIP data that you got at the activation page / by mail (depending on the federal state) into the phone configuration page of the FritzBox -and- you will need to assign the correct number to the Tel1 port.
