Vodafone Station 6 WIFI light is off
Viandy_Marco
Hello,
My router's WIFI is turned off since 2 days ago, when I tried to restart it. A week before this I can't use the WIFI for certain apps, that's why I restarted it. But now the WIFI doesn't work (the WIFI light on the router is turned off, if I try to press the WIFI button it will just blink continuously), but the internet light is on.
I went to a Vodafone shop to ask, and the guy said that he can't see a problem with the contract. Then he told me to call customer service, which doesn't help. They only told me to restart the router, which I already did multiple times and the calls always end abruptly.
I would appreciate some help. Thanks!
RobertP
try a factory reset (press an hold reset with a paperclip for 20 seconds)
4 Antworten 4
Since August 15th, 2022 there is no more individual support here in the forum. Support in English is available via Facebook or Twitter.
Best regards Kurt
RobertP
Oh that did it I guess I didn't hold it long enough the first time I did it. Cheers brother!
Then I close the thread.
Best regards Kurt
