Frequent Disconnection of Internet from Router
Sivas
Hi
I have Vodafone Cable Max 1000 from September 2021.
There was no problem untill now.
From last i notice the internet disconnects frquently for very short time.
It just reconnects  after very short time in seconds and network is down for the some seconds
Info Community-Team: Post moved to appropriate board
ERFD
Hello Sivas,
is the network then gone for all devices at the same time? Via LAN and WLAN? Or does this only affect certain devices? Which modem with which firmware do you use exactly? In which postal code area do you live?
Regards Fred
