Disruption of Internet Kabel
Enya921
Hi there,
We recently have some problems with our Internet connection. Often a message of "no Internet connection" is displayed when we tried to connect to the Wifi.
Could you please let me know what kind of information you need from us so that you can help out?
Thank you very much for your kind help.
With Kind Regards,
Siyu
Hello Siyu,
is only the WiFi connection affected or the ethernet connection as well? If the ethernet connection works, please check the hints for the WiFi optimisation. Did you reset the router to the factory settings already?
Kind regards
