01.08.2021 12:27 - bearbeitet 01.08.2021 12:30
Hello, I've got the kabel internet package of 1000mbs from vodafone. I have it installed since 2 days, I called the helpline to activate it and I was told it was activated and it would start working in 15 minutes. It didn't work for hours, I called again, and I was told to wait another 24 hours. It didn't work again. I called yesterday again, and I was told that my contract wasn't activated yet (?????). Then, I was told they activated it, and now it should work in 15 minutes. Its been 18 hours, still no internet. When I call the technical helpline, I'm told by the guy (in perfect english) if I need help in english I should post here.
could someone help here?
Answers for possible questions
All lights are on in white constantly (internet, power, wifi, phone. I',ve unplugged/replugged the power and cable. Reset the router. Still no internet.
Hopefully help here is fast,
Thank you.
am 13.08.2021 13:29
since you chose Twitter as your support channel I'll close a post with this.
Regards
Wallace
am 02.08.2021 14:11
Hello Mudasir,
if the LEDs are blinking, the modem has no connection to our network. It is a pity that the previous measures did not lead to a connection. We would like to have a look at your connection and the problem. Please send us the customer number, name incl. address and date of birth of the contract holder via private message.
Write here briefly when the data has been sent.
Best regards Fred
am 05.08.2021 15:23
I've sent the details in PM. It's been 5 days now, still no internet. My 14 days right of withdrawal is soon expiring, please reply asap so I can decide wether I want to be stuck with this expensive but useless service for 2 more years.
am 06.08.2021 10:16
Hello Mudasir,
the connection to the CMTS is OK. The signals on the modem are also OK. The modem itself does not get a public IP address. Can you please try a factory reset with the modem? Otherwise a technician will have to take a look at this.
Best regards Fred
am 06.08.2021 12:15
I just noticed that under Privatkunden > MeinKabel > Meine Vertragsdaten > Internet & Phone > Options, I should see IPv4 Address. But It's not showing that option, Its only showing WLAN.
I was just told by the customer care on twitter that there might be software issue, and that they'll update my router software remotely. After the update, the wifi light went off, and now I cannot even connect to wifi. Only lightts on are now POWER, INTERNER and PHONE.
This is extremely frustrating. I call the helpline, they tell me there's a grid failure in my area and open a ticket. I come here, you tell me my router doesn't have public ip address. I go to twitter, they tell me my router's software is out of date.
I'm done! could you please explain to me process for cancelling the contract? Can I send the email or I have to send the cancellation by post?
am 06.08.2021 13:30
I have reset the router as well. Still no internet, could you please have the technician take a look at it?
am 06.08.2021 14:35
Hello Mudasir,
this is not a reason to quit. These are just teething problems. According to the modem, a public IP address is now stored. Can you see this via the interface? Can you please try a factory reset after the software update, otherwise the modem is probably not in order.
Please decide for one channel, otherwise it will go in different directions 😉
Best regards Fred
am 06.08.2021 21:40
I still can't see the IP address iption in the interface. I still can not access the internet. Not sure where you see that I have IP now
am 09.08.2021 16:30
Hello Mudasir,
we see, that the cable-router get an IP-address from our network. Please try a connection with ethernet to the cable-router.
Do you get internet now?
Regards
Jens
am 10.08.2021 23:53
I don't have ethernet adapter for my macbook so I have not tried with ethernet cable. When I connect to wifi, the internet doesn't work and I can't access the router config either on 192.168.0.1. In the Meine Vodafone > Booked Options, I don't see that my router has public ip option?
2 weeks on and no internet. I keep going back and forth with the same arguments, with you guys replying 24 hours after my questions only to get no where.. Is it possible to schedule a call/visit with a technician who wouldn't mind speaking english?
