Cancellation Help and Suggestions
Sue_2
I write this message to assist others with their attempts to cancel / terminate their Vodafone contracts.
I am an English speaker with limited understanding of spoken German so calling was impossible. I apologize for not becoming more proficient. All I will say is COVID.
In May 2022, on the Vodafone website, I cancelled my contract… Or so I thought. Three weeks later, having received no response, I went back to the website and discovered another way to cancel. I did so, or so I thought. Three weeks later, with no reply, I discovered this Forum.
The solution to 6 weeks of trying to cancel came from this forum. I found a link in “Moving Abroad – Leaving Germany”,
“As a cable customer you can inform us of your move here using this form.” i.e.: http://vod.af/umzugemelden .
On the same day I sent it, I received a Cancellation Confirmation E-Mail with the Cancellation Confirmation Letter attached!
To save everyone who is looking some time, use this link to cancel a contract if you are moving abroad: http://vod.af/umzugemelden
The Cancellation Confirmation Letter states that the equipment you have must be sent back, preferably by DHL. A link is given that does not work. I found the correct link: https://kabel.vodafone.de/retoure?desktop=1
I hope this helps.
Edit: Beitrag in passendes Board verschoben. Lars
Grit
Hello Sue_2,
thank you for your feedback. We also have a help page in this forum for the topic of moving There is also the topic of moving abroad.
Regards
Grit
2 Antworten 2
Grit
Hello Sue_2,
Regards
Grit
Since the solution has been marked here, I'll close now. If you have any questions or concerns again, just start a new thread in the correct board. Please note, however, that direct support is no longer possible here. It is best to read this article.
