number of TV /box
Odette
Good Morning
Is it possible to have a TV in the living room and one in the bedroom using the same box?
*** @Odette, moved from Feedback to GigaTV ***
Hello Odette,
you can only use one TV per GigaTV box. If you want to use GigaTV in more than one room, the GigaTV Net Box with the multi room option might be interesting for you.
Kind regards,
Mav1976
Hi @Odette,
is your request related with cable or DSL?
Hi
To be more precise: I have a Giga TV set with Vodafone. I use it to wath TV in my living room. I have other TV plugs in the bedrooms. If I want to watch TV in one of the bedrooms can I use the same box?
Hello Odette,
Kind regards,
