Wrong upload and download speed
sid7
Hello Everybody,
This is my first post.I need your help and advise here.
My contract at the moment is : "Red Internet & Phone 100 Cable" with which I use the standard router which was provided by Kabel Deutschland  (not Fritzbox).
When I check the speed on https://www.speedtest.net/ , it is always less. Download fluctuates between 16 - 30 Mpbs and Upload = 4 - 10 Mbps.
5 years ago I had "Red Internet & Phone 25 Cable" which I changed to the plan above last month and I don't see any improvement. Calling to the technical support is also not very helpful due to my poor German.
Can you help me uderstand what is wrong here ?
2 Antworten 2
ERFD
Hello sid7,
welcome to the community 🙂
Are you running the tests via Gigabit LAN directly on the modem or via WLAN? If it is WLAN, have you tried to optimize the connection?
Best regards Fred
Thanks for you response and Sorry for my late reply.
I am running the tests via WLAN. Let me go through the article related to optimization and I will let you know.
May thanks for your help.
