am 05.10.2020 15:42
I lost access to the internet at around 18:00 yesterday. I tried pinging the router, but it failed. Apparently, the IP address lease had expired and I got a self-assigned IP (169.x.x.x). Looks like the DHCP server has been down since then. I tried assigning the address manually (i.e. 192.168.0.100) and the router was reachable. However, when I tried logging in at http://192.168.0.1 to check what the issue was, I would get "Invalid username or password", which is strange since I hadn't changed the password. I also tried resetting the router to the factory settings multiple times, but to no avail. I did double-check the password, it was correct.
The device is technicolor cga4233de. Both the Internet and Phone lights are glowing white. Is there anything else I could try?
Thank you
am 12.10.2020 13:26
Hi internet_user,
I´m glad to read that everything is ok now. Hope it will stay so 😉
If not, you know where to find us.
I think I can close this thread for the technician has solved it by replacing the router.
Best Regards, Manu
@playforvoices Da Du ja in Deinem Thread mit Claudia in Kontakt stehst, denke ich, dass sich bei Dir auch bald eine Lösung ergibt.
am 05.10.2020 20:17
Hi, exactly the same problem here. I lost connection today 6:45 in the morning. No DHCP lease from the Vodafone Station. If I give my PC a manual address in the network, so I can reach the Station but aren't able to login. Also, a reset didn't work. The factory reset login simply didn't work.
05.10.2020 20:21 - bearbeitet 05.10.2020 20:29
Hier nochmal in Deutsch. Heute früh gegen 6:45 Uhr keine Verbindung zur Vodafone Station möglich. Sie vergibt keine DHCP Adressen mehr. Den PC per manueller Adresse ins Netz gebracht, dann war die Station zu erreichen. Allerdings kein Login möglich. Das gleiche Problem nach dem kompletten Reset der Station.
Das Teil dürfte wohl damit hinüber sein. Eventuell ist da ein Firmware Update schiefgelaufen?
Bitte um Hilfe für dieses Problem.
--M.
am 06.10.2020 12:53
Hi internet_user,
I like to look at the connection, I need your name, address, date of birth and customer number in a PM.
Let me know here again when the message is sent.
Many greetings, Manu
@playforvoices mach bitte einen eigenen thread auf, dann schauen wir auch nach Deiner Station
am 06.10.2020 13:10
Hi Manu,
I've just sent a PM.
am 06.10.2020 17:47
@ManuDanke Dir. Habe schon eine PM mit allen wichtigen Daten an Claudia geschickt. Hoffe, das ist auch okay. 🙂
am 07.10.2020 14:56
Hello internet_user,
at your connection some signal values do not fit any more, so a technician has to have a look at it.
Please send me a PN with your mobile phone number and the information if you can access the house system.
Many greetings, Martin
am 07.10.2020 15:21
Hi Martin,
Sent a PM.
am 09.10.2020 11:48
the technician is informed and will contact you soon.
Regards
Wallace
am 09.10.2020 21:34
Hi everyone,
Just wanted to let you know that the issue is now resolved.
A technician came over today. He checked the signal and it didn't look good. So we went downstairs to the basement where he replaced a part in the distribution box. This normalized the signal, but unfortunately, didn't fix the original issue. Apparently, the problem was in the router itself, since when it got replaced everything went back to normal.
Thanks again for all your help.
@playforvoices I hope your issue is resolved soon as well.
