am 13.03.2020 18:22
I have cable home internet 1000 Mbps. It works just fine and get download rates at up to 100 MBps sometimes
The problem is when I use VPN (company network), the connection is slow and I can only download or transfer at ~ 300K Bps, given that my company's VPN is way faster.
Thanks.
am 16.03.2020 13:30
Hi mhaiba,
what connection speed does your company provide?
Best Regards, Manu
am 21.03.2020 18:35
Multiple 1Gbps VPN connections.
am 21.03.2020 22:24
Hey @Manu,
I was promised IPv4 (to fix the VPN problem) from the customer service a week ago, but it isn't activated until now. Can you help with that?
am 24.03.2020 08:59
Hi mhaiba,
I can have a look, if the colleagues activated IPv4.
Would you please send me your name, date of birth, address and customer number via PM?
Please sign in here again, when the message is sent.
Best Regards, Manu
am 29.05.2020 21:33
Hello, I have same problem.
I have a cable connection and it works fine, pretty goon internet about 200MBit download speed. When I'm trying connect to company VPN everything what goes threw VPN has very slow speed a ping about 1500 - 3500 ms. Company VPN definetly not a problem, it has multiple 1GB connections and work fine for more then 100 people. Even work good for me if I'm trying to connect via LTE connection from my phone.
am 02.06.2020 12:45
Hello ivasyliev,
the error only comes in the VPN? Have you had your company check if everything is ok there?
Best regards
Moni
am 04.06.2020 20:20
Yes, they tried and checked many things and really everything works for a large number of people. Everything looks good on their part. They tell me to contact you because the problem is in the connection between my computer and VPN.
Thanks,
Ivan
am 06.06.2020 12:31
Hi Ivan,
please send me your name, address and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
am 06.06.2020 20:01
Hello Marco,
I just sent you a private message.
Regards,
Ivan
