am 19.05.2020 13:36
Yesterday (18th May) I noticed that I wasn't able to reach some hosts and my first suspicion was that the target hosts were to blame since everything else seemed to be working fine. After some more investigation I now think there might be some routing or peering issues.
The hosts from my troubleshooting are: 185.39.10.39 and 85.92.108.102. I've used some command line tools on my mac to diagnose.
1st step: trying to establish a connection:
$ nc -vz 85.92.108.102 8080 nc: connectx to 85.92.108.102 port 8080 (tcp) failed: Operation timed out $ nc -vz 185.39.10.39 8080
nc: connectx to 185.39.10.39 port 8080 (tcp) failed: Operation timed out
2nd step: establish the path to one of them:
$ traceroute 85.92.108.102 traceroute to 85.92.108.102 (85.92.108.102), 64 hops max, 52 byte packets 1 fritz.box (192.168.0.1) 3.861 ms 1.068 ms 1.579 ms 2 ip5b4065fe.dynamic.kabel-deutschland.de (91.64.101.254) 19.031 ms 15.189 ms 16.924 ms 3 83-169-180-142-isp.superkabel.de (83.169.180.142) 15.727 ms 12.959 ms 16.344 ms 4 ip53a99c95.static.kabel-deutschland.de (83.169.156.149) 29.252 ms 12.041 ms 10.864 ms 5 145.254.3.66 (145.254.3.66) 14.303 ms 16.982 ms 9.568 ms 6 145.254.2.187 (145.254.2.187) 21.009 ms 27.651 ms 26.054 ms 7 145.254.2.187 (145.254.2.187) 26.374 ms 29.245 ms 35.338 ms 8 ae4-0.ams10.core-backbone.com (80.249.209.128) 41.625 ms 28.845 ms 64.807 ms 9 core-backbone.global-layer.com (5.56.20.22) 27.086 ms 51.936 ms 37.298 ms 10 185.23.212.5 (185.23.212.5) 32.319 ms 30.292 ms 31.075 ms 11 185.23.212.9 (185.23.212.9) 91.471 ms 45.881 ms 205.050 ms 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * *^C
After hop #12 it just goes on and on until it'd hit the 64th hop and give up. This initially suggested that the target host would be down. After checking with 3 friends with the following internet providers/options (1und1, Vodafone-DSL and Vodafone-Kabel such as myself). They all reported being able to establish these connections.
% nc -vz 85.92.108.102 8080 Connection to 85.92.108.102 port 8080 [tcp/http-alt] succeeded! ... $ nc -vz 85.92.108.102 8080 Connection to 85.92.108.102 8080 port [tcp/http-alt] succeeded! ... Connection to 85.92.108.102 8080 port [tcp/http-alt] succeeded!
3rd step: Try using a VPN provider (protonvpn):
$ traceroute 85.92.108.102 traceroute to 85.92.108.102 (85.92.108.102), 64 hops max, 52 byte packets 1 10.1.0.1 (10.1.0.1) 39.161 ms 29.662 ms 57.401 ms 2 37.120.217.162 (37.120.217.162) 22.439 ms 25.503 ms 31.757 ms 3 37.120.217.161 (37.120.217.161) 150.143 ms 28.772 ms 37.147 ms 4 37.120.220.134 (37.120.220.134) 23.753 ms 24.951 ms 31.336 ms 5 37.120.220.119 (37.120.220.119) 44.062 ms 37.120.128.148 (37.120.128.148) 29.784 ms 22.751 ms 6 37.120.128.253 (37.120.128.253) 21.409 ms 25.129 ms 19.930 ms 7 ae3-1.fra20.core-backbone.com (80.81.192.187) 40.074 ms 26.378 ms 29.766 ms 8 ae5-2074.ams10.core-backbone.com (81.95.2.138) 41.619 ms 29.200 ms 34.227 ms 9 core-backbone.global-layer.com (5.56.20.22) 35.442 ms 40.730 ms 54.812 ms 10 185.23.212.5 (185.23.212.5) 37.281 ms 54.610 ms 58.951 ms 11 185.23.212.9 (185.23.212.9) 623.981 ms 96.037 ms 193.490 ms 12 85.92.108.102 (85.92.108.102) 29.099 ms 33.387 ms 30.099 ms
I am able to reach the target host successfully.
I have also forced traceroute to do TCP tracing (traceroute -P TCP -p 8080 85.92.108.102) but that fails as well without the VPN.
Any chances this could be looked into? I feel there's currently a part of the internet I am unable to reach 😞
am 23.05.2020 20:50
I've managed to workaround the issue by "forcing" a new DHCP lease for my cable modem. Using the "Reconnect" option in the FritzBox or even turning it off and back on with only a couple of second in between resulted in the same IP addresses being assigned. While I had the same IP addresses (IPv4 and IPv6) the rotuing problem persisted.
After keeping the cable modem off for ~15min and turning it back on I got new DHCP leases - new IPv4 and IPv6 addresses. The problem disappeared immediately and I am now able to reach the targets successfully. What gave me the hint of it being a routing problem was the fact that another Vodafone/Cable customer in Berlin being able to reach the target while I couldn't. The traceroute output for both of us was different (mine never returned).
Let me know if providing you my customer details as well as the old and new IP addresses can help with additional troubleshooting.
Thanks
am 23.05.2020 20:35
Hello lmineiro,
is the disturbance still in progress?
If so, please send me your name, address, date of birth and customer number by PN.
Please let us know here as soon as you have sent the message.
Best regards, Martin
am 23.05.2020 20:50
Thanks
am 27.05.2020 21:29
Hello, Imineiro,
do you notice any interference now, or does it work?
Best regards
Moni
am 28.05.2020 12:06
It works currrently with my new IP address. I can't guarantee if the problem will come back when my DHCP lease is renewed.
am 30.05.2020 10:47
Hello lmineiro,
then keep watching and report back here when the problem is solved.
Best regards
Moni
