Langsames Internet
Maria_Eleni
Hi, since the last week I am having problems with my internet connection. My internet download speed is very slow. My Cable contract is mormally for 200Mbps Download and 12Mbps Upload but my actual speed is 12Mbps Download and 12Mbps upload. The same happens even if I try through ethernet cable or through WiFi. Why is this happening? Thank you
Marcus89
Hi Maria_Eleni,
so would you agree to replace your device? The new device would arrive within 3-5 business days. After that the old router must return to us within 14 days.
Kind regards
Marcus
11 Antworten 11
ERFD
Hello Maria_Eleni,
is the restriction permanent or only at certain times? Has the cabling on the modem been tested for strength? Has it been tested with different devices?
Best regards Fred
Hi ERFD,
The issue is happening all day long, not only on specific times. I have tested with different devices and cables and also with Wifi and the problem is the same.
ERFD
Hello Maria_Eleni,
please send me once your customer number, your address and your date of birth by private message. I'll take a look at your connection. Give me a short feedback here when you have sent the data.
Best regards Fred
I have sent you the info requested.
ERFD
Hallo Maria_Eleni,
die Signale am Modem sind in Ordnung und eine Auslastung ist nicht sichtbar. Vielleicht ist das Modem defekt. Kannst Du es bitte resetten?
Gruß Fred
I did the reset to factory settings but the internet is still slow. Please see attached image.
Marcus89
Hi Maria_Eleni,
Kind regards
Marcus
For the last 4-5 days the speed seems to be back up to normal levels.
So for the moment I don't think there is need to change the router as the problem seems fixed.
Regards
Maria Eleni
Wallace
is it okay if I do your thread here or do you want to watch the situation for a few more days?
Regards
Wallace
