am 23.11.2020 20:39
Hello, since the beginning I've had performance issues with my internet connection. It's supposed to be 1 Gb but sometimes(too oftenly) is worse than a 2000s DSL, the fastest I have obtained was somewhere between 700-800Mbits/s. Saturday night (23:00-00:00), for example the Download speed was between 3 to 7 Mbits/s, while even upload was better at 12-15 Mbits/s. That happens everyday, the connection gets lost, no matter how many times I reboot the router.
Please I need support with this, as it's unbearable.
Thank you.
Thank you.
am 13.03.2021 19:43
Hello Martin,
I disagree, but well, nothing else to comment about it.
I would like to know how would be the process, given that Vodafone didn't fulfill his part in the contract by not providing enough upload speed, of voiding the contract and thus allowing me to change the service provider without any obligation with Vodafone.
Thank you.
Regards,
am 16.03.2021 21:22
Hi FrankDiana,
what speed do you get after the technicians visit over the day?
Kind regards
am 22.03.2021 16:49
Hi Marco,
As you can see in the previous page, Upload was less than 5 Mbits/s.
Could you please answer my previous question? Thank you.
Kind Regards,
am 25.03.2021 09:13
Hello FrankDiana,
You can terminate your contract as normal at the end of the contract. There is no reason for an early termination of the contract.
However, we will be happy to help you if your connection is still faulty. What are the current speed test values measured with Lan?
Many greetings
Jana
am 25.03.2021 20:46
Hello Jana,
Usually, a violation of the terms of a contract, voids the contract. Since Vodafone hasn't complied with the minimum upload speed (15 MBits/s for 1000 MBit/s service), why do you say there's no reason?
Regards,
am 26.03.2021 10:33
Hello,
Your last disturbance order was in January. This does not justify a special termination.
However, if you want to cancel, then at the regular end of the contract period.
We will be happy to help you here if you have a fault. Send us current speed test results measured with LAN. When does the fault occur, the whole day or only at certain times?
Then we will check your connection.
Many greetings
Jana
am 26.03.2021 19:05
Hello,
Last image is from Feb 20th, not January. Where can I see the conditions required for a special termination?
I've spent too much time waiting for your solution, and even then you only provided a solution where I had to pay for something caused by VF, so no, I don't want more support. Thank you.
Regards.
am 29.03.2021 07:22
Hello FrankDiana,
there are no conditions for a special termination. Termination for failure to provide contracted service with a reasonable deadline to remedy the problem. In written form not publicly in this forum.
Best regards Fred
