am 05.02.2020 19:54 - zuletzt bearbeitet am 08.04.2020 18:55 von Tina
I had problems with Vodafone router. I reported issue to online service, they were not able to help me as my problem is regarding technical service. Instead online service gave me a technical service number, which has automatic german reply with no possibility to switch it to english. After numerous tries to contact real people, 2-3 technical specialists were not able to speak english. I tried my best to explain in german that I need an appointment with master to see what are the problems I have with my router, but contact persons were not interested in making appointment for me unfortunately.
Then I decided to report issue to WhatsApp bot which 90% of time doesn't work and replies to me after a day or something. Fortunately I was able to report issue and after several days I received call, but didn't have time to respond as call lasts only 1-2 seconds and I had time just to take my phone and see then someone is calling. For me it's clearly call to mark that you called me, but I didn't respond. No one contacts me since that.
So not at all satisfied
Mod Edit: @IgorDrozdov Moved from "Feedback" to the right board.
am 06.02.2020 13:32
Hello @IgorDrozdov,
thanks a lot for your feedback. Only through this can we put the process to the test.
In order to be able to assign this better: Was it Internet via DSL or cable?
Best Regards
Sebastian
am 06.02.2020 13:37 - zuletzt bearbeitet am 06.02.2020 13:50 von MasterScorpion
I don't know. My Kunden-Nr. ****
Deleted private data, MS
am 07.02.2020 15:05
I'd be happy to take a look at the connection 🙂 Do you send me your customer data (customer number, name, address and date of birth of the contract holder) via private message?
Then please let me know in the post when you have sent me the data.
Regards
am 07.02.2020 15:11
Hi!
Message has been sent
07.02.2020 16:18 - bearbeitet 07.02.2020 16:19
i want to have this checked by a technician, can you send me your phone number where an appointment can be made via private message? Im sorry to cant help you directly ;/
Regards
am 08.02.2020 09:50
Phone number has been sent
am 09.02.2020 10:57
Hello Igor Drozdov,
the technician is assigned. The colleague will call you to make an appointment.
Kind regards
Moni
am 10.03.2020 22:13
am 11.03.2020 15:42
Hello, Igor Drozdov,
yesterday there was an increase in line errors. But these are no longer present. Has it calmed down again?
Best regards
Moni
