want to downgrade my tarrif
Pooja
I want to Downgrage my Kable Internet from 1000Mbps to 50Mbps
can someone help for this?
My couster number : ***
Thank you
Edit: Customer number removed for data protection reasons. VF_Grit
Anett
Hello Pooja,
thanks for your PN and your data. 🙂
A change to Internet & Phone 50 is possible on 24.03.2021. If you like, I will make everything ready.
Regards
Anett
7 Antworten 7
Anett
Hello Pooja,
welcome to the community. 🙂
I will gladly help you with the downgrade. In order for me to do so, I need your data (name, customer number, address and date of birth) via PN.
As soon as this is out, please contact me again here in the post.
Regards
Anett
Pooja
Hello Team.
i sent the details in private message,
Kindly check and downgrade my internet tarrif
Anett
Hello Pooja,
Regards
Anett
Pooja
Hello Anett,
Thank you for your information.
I'm confirming  you : please downgrade to 50Mbps.  (from 24.03.2021)
Thanks for your support
Regards,
Pooja
Anett
Hello Pooja,
I finished the change. You will receive a written confirmation in March.
Regards
Anett
Pooja
Thank you So much...
this portal helps lot.
Nancy
Hello Pooja,
we are happy to read.
Since everything could be cleared with you, I will put a lock on your thread.
Best regards
Nancy
