am 18.11.2018 14:12
Hi there
Since thursday my router (KabelRouter) stopped broadcasting signal on 2.4 Ghz. It works on 5 Ghz only. I have two laptops and one mobile phone without internet anymore. I tried unplugging the router several times, also removing known networks from mobile and laptops and rebooting them, but they just can not find the SSID. Also tried to change the channel for 2.4 Ghz, in case there were signal problems on that channel, but the router always keep using channel 1.
Looking at the router status I also realized it was restarted some hours before I noticed the 2,4 Ghz network stopped working, and I did do that, so I guess there was firmware update ?
Kind Regards
Sergio
am 19.11.2018 17:02
Hello Sergio39,
what's the type of the router? Did you try a factory reset?
Kind regards
am 20.11.2018 19:00
Hi Claudia
I did try factory reset, just tried once again, but no luck. SSID still does not appear in 2.4 Ghz band.
Please find firmware version in case it helps
The router model is WLAN-Kabelrouter Vodafone Station (ARRIS tg3442de)
Firmware-Version AR01.01.117.01_091718_70.PC20.10
BR
Sergio
am 22.11.2018 20:02
Any idea ?
BR
Sergio
am 23.11.2018 08:17
I can have a look at the connection 🙂 Could you send me your customer data (customer number, name, address) via private message?
Please let me know in the article when you have sent me the data.
am 25.11.2018 16:35
Hi Tobias
Thanks for taking a look. Just sent you a private message witht the data.
BR
Sergio
am 28.11.2018 10:37
Hello, Sergio39,
can the connection be set up manually with SSID, type of encryption and password?
Best regards Fred
am 29.11.2018 21:12
Hi
Unfortunately not, the devices are not able find the SSID (those who use only 2.4 Ghz)
Best Regards
Sergio
am 07.12.2018 11:49
Hi Sergio,
Is it okay if we switch routers?
Regards
Wallace
am 12.12.2018 19:58
Hi Wallace
Whatever we need to address the issue. Just let me know which is the process.
Thank you !
Best Regards
Sergio
