am 08.07.2018 13:14
My Moto G5 Plus frequently disconnects at my home. That doesn't happen to other locations. I am using FAST5460 Wireless Voice Gateway provided by Kabel Deutschland. It's firmware version is 6.0.1.49-IMS-KDG. I have already tried the following debug options, but that didn't change the behavior:
1. Power cycle the router
2. Reset the router
3. Forget 5 GHz SSID on the phone and keep 2.4 GHz
4. Forget 2.4 GHz SSID on the phone and keep 5 GHz
Writing to Vodafone support got a cold response saying "can't help in your preferred language (that's English). It instead asked to write here. Can you help?
Thanks,
Tanmay
am 19.07.2018 18:33
Hello Tanmay,
I sent the mail to your GMail-Account, you may look for "Vodafone-Team". But your modem got a new firmware today, which should eliminate the problem with the disconnects. Could you already test this?
Kind regards
am 10.07.2018 09:01
Hello Tanmay,
those disconnects might occur with the combination of the current firmware and certain devices. There will be a new firmware in the next few weeks, if you send me a PM with your address and customer number I can make a fault report for you. Please reply in this thread again when you sent the data.
Kind regards
am 10.07.2018 20:47
Hi Claudia,
I have sent you the data.
Thanks,
Tanmay
am 12.07.2018 13:55
Hello Tanmay,
as mentioned in my previous message, I made the fault report. You should get an E mail as a confirmation.
Kind regards
am 16.07.2018 20:22
Hello Claudia,
I have a similar problem with my Sagemcom router provided by my contract and my phones (Moto G4 and G5S). The router constantly disconnects my phones from the wifi. How will the new firmware be installed?
Cheers
am 17.07.2018 15:51
Hello Vanwe,
please open an own thread with a short description of your problem. We will contact you there.
Kind regards
am 18.07.2018 13:31
Hi Claudia,
I haven't received the email so far. What keywords should I look for, just to check if it's in "Junk" folder? Would it contain the next steps to do? How do we move forward from here?
Thanks,
Tanmay
am 19.07.2018 18:33
Hello Tanmay,
Kind regards
am 30.07.2018 23:46
am 01.08.2018 15:38
Nice that it worked so fast with the update. I'll close up here.
Regards
Wallace
