Internet connection is unstable
OmarMahmoud
I have a cable internet, it disconnects on random intervals and stays for a while before connecting again. I would say this is happening very frequently, it is becoming very annoying. I followed all the instruction of the bot, but nothing helped, it keeps happening for nearly a month now.
10 Antworten 10
zappzarapp
- Can you share your location?
- Do you see disconnects in your router (FritzBox?)
- Does it happen 24h or at specific times during the day?
- I live in Munich near Drygalski-Allee.
- Yes, I can see no other LED other than power at the time of diconnection.
- I do not know, I think it is completely random through out the day, no specific time.
Since August 15th, 2022 there is no more individual support here in the forum. Support in English is available via Facebook or Twitter.
Best regards Kurt
Tried to reach them through facebook, but I got no answer !!!!
Hi @OmarMahmoud,
Since our colleagues are in great demand on Facebock and Twitter, it may take a while before you hear back. As soon as they have checked your request, they will answer you as soon as possible. 🙂
Kind regards
R4mona
It has been more than a month now with bad connection, No call back, no response, nothing.
Right now the wifi signal is completely cut, wifi LED never on now, and still no response from them.
How is this even still a thing?
which router do you use?
standard router aka Vodafone Station?
factory reset already executed?
(press and hold reset button for at least 20 seconds)
Yes, vodafone station.
Factory reset executed and solved the wifi outage problem, but the internet instability still persist, and I got no response from Vodafone service on facebook messenger.
I did reset still my Wifi light remains off, any suggestions ??
