am 14.06.2022 00:23
Hi
My vodafone station router WiFi disconnects every (about) 10 minutes and all connectede devices disconnects and reconnect after some seconds. The problem is not from Internet, as internet works good. Just wifi disconnects frequently and reconnect again.
I tested many things and configs but not fixed the problem (separating 2.4G and 5G, changing WiFi channel, router reset factory)
am 14.06.2022 10:01
Hi Arman,
Is the problem also with devices that are connected to the router via a LAN cable?
Regards
Wallace
am 14.06.2022 10:28
Hi Wallace
Thanks for your response.
No, with LAN cable everything is good.
Regards
am 14.06.2022 11:40
According to the system, the 2.4 and 5GHz networks have had the same SSID for at least 14 days. Can you please assign separate SSIDs?
Regards
Wallace
am 14.06.2022 12:09
am 14.06.2022 13:19
Okay, then I'll gladly swap the router. Is that OK?
Regards
Wallace
am 14.06.2022 13:24
Thank you so much.
Yes, It is OK for me.
Just because my German is not good, I can't coordinate with customer service in German 🙂
Kind Regards
am 15.06.2022 10:49
No problem,
we will manage the exchange this way. 😉
I have just initiated this.
The new device will arrive in the next few days.
Please connect it as usual and send the old device back to us.
If there is still something wrong, please contact us again.
Best regards, Martin
PS: You'll get another PN from me soon. Please take part in the survey in it once.
