am 05.10.2020 14:14
Dear Vodafone team,
I'm trying to enable Port Forwarding on CH7466CE router with no success.
According to the user manual page 29: https://kabel.vodafone.de/static/media/Compal_WLANRouter_CH7466CE.pdf , it should be possibel to set IPv4 port forwarding rules, but this option seems to be not available on SW version 4.50.21.4. Also DynDNS component is also missing.
Can this option be activated?
Regards,
Dragos
05.10.2020 14:41 - bearbeitet 05.10.2020 14:43
Hello,
port forwarding is not available if you are connected with DS LITE.
You have no public IPv4 any longer. You can activate Bridge Mode and use your own router, in ths mode you will get public IPv4 and you can setup port forwarding on your router.
regards Robert
Hello,
regards Robert
am 05.10.2020 17:28
Is it possible to get back to DS LITE - "nominal-mode" after Bridge-Mode ?
Just in case I will not be happy with the Bridge-Mode operation.
Can I send the request to Bridge-Mode: "OFF" in the same way as activating it ?
Privatkunden -> MeinKabel -> Einstellungen -> Interneteinstellungen -> Bridge Mode einstellen
am 05.10.2020 17:48
yes this is possible without any problem 😉
am 05.10.2020 17:51
Yep - you can easily switch back.
