Vodafone Station CGA6444vf keeps dropping from the connection and reboosting itself
erendaglar
I have a Vodafone Station CGA6444vf router and it keeps dropping from the connection and reboosting itself.
It is frustrating. I can’t work properly and I can’t play games. It started almost 2 weeks ago.
What I have tried,
  • Turning it off and on again after 10 seconds.
  • Resetting manually.
  • Reboosting manually.
  • Changing the location.
  • Using different coaxial cable.
  • Disabling band steering
Sometimes, even my SSID becomes default. How can it be possible? I have read that the band steering might cause this problem so yesterday I disabled band steering and separated SSIDs , nothing changed.
I do not know speak German, please someone help me.
  • Which modem/ router are you using?
  • Do you use a rental device from us or do you have your own device?
    Rental
  • How is your device connected to the modem? ( LAN; WLAN; additional router; PowerLAN )
    Via WLAN
  • Which browser do you usually use? (e.g. Firefox)
    Google Chrome, Safari
  • Which operating system do you have on your computer? (e.g. Windows)
    Mac OS X
  • Start and period of the disruption (e.g.: since the beginning of April; only in the evening)
    It has been happening for 3 weeks.
gnai
did you find a solution for this ?
Since August 15th, 2022 there is no more individual support here in the forum. Support in English is available via WhatsApp
The forum is now just a customer helping customer forum.
Best regards Kurt
aaj
Ich habe ein absolut identisches Problem. Ständige Verbindungsabbrüche.
Ich werde versuchen, die Ausrüstung auszutauschen. ☹️
