IP address changes frequently
su6
Hello.
I started to use vodafone internet from last month.
I don't want to change my IP address often because of my work, but my current internet changes my IP address two or three times a day.
So I checked my router and realized the following error logs occurring several times a day.
k2_SSID Device [Mac Address] disconnected from SSID Device.WiFi.SSID.2 REASON-CODE=3.
k2_SSID Device [Mac Address] disconnected from SSID Device.WiFi.SSID.2 REASON-CODE=4.
k2_SSID Device [Mac Address] disconnected from SSID Device.WiFi.SSID.2 REASON-CODE=15.
I tested many things and configs but not fixed the problem (separating 2.4G and 5G, changing WiFi channel, router reset factory)
If this error is resolved, would it prevent the IP address from changing frequently?
Please let me know if there is a better solution.
  • In which state do you live? Düsseldorf
  • What contract do you have? GigaZuhause 250 Kabel
  • Which modem/ router are you using? Vodafone CGA6444VF
  • Do you use a rental device from us or do you have your own device ? rental device
  • How is your device connected to the modem ? WLAN
Wallace
Hi su6,
We should take a closer look at that. Can you please contact our Twitter or Facebook support via DM?
Regards Wallace
