- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am 26.11.2024 15:47
I have recently switched to the Vodafone 1000 Cable Max plan. Since the change, I have been facing severe issues while trying to connect to my employer's network using a VPN. My previous internet connection did not present any such challenges.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 27.11.2024 11:11
Good morning @rohitsharma,
I'm sorry to read that you can't use your connection properly. 😢
Did you receive a new router when you switched to our CableMax? What exactly do you see when you try to connect with VPN?
Kind regards
R4mona
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 27.11.2024 11:11
Kind regards
R4mona
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 28.11.2024 09:21
Thank you for reaching out and for your concern. I wanted to update you that the issue has been resolved by my employer's technical team.
The problem was caused by an outdated configuration on our router. I truly appreciate your support and quick response during this time.
If I encounter any further issues, I’ll be sure to reach out. Thanks again for your help!
Kind regards,
Rohit Sharma
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 28.11.2024 12:32
The thread has been marked as resolved. Then I'll close the thread here.
Best regards Kurt
