An error occured! templates/dsl-kabel/_help.html (No such file or directory) java.io.FileNotFoundException: templates/dsl-kabel/_help.html (No such file or directory) at java.base/java.io.FileInputStream.open0(Native Method) at java.base/java.io.FileInputStream.open(FileInputStream.java:213) at java.base/java.io.FileInputStream.(FileInputStream.java:152) at clojure.java.io$fn__11655.invokeStatic(io.clj:232) at clojure.java.io$fn__11655.invoke(io.clj:232) at clojure.java.io$fn__11607$G__11561__11614.invoke(io.clj:72) at clojure.java.io$fn__11629.invokeStatic(io.clj:168) at clojure.java.io$fn__11629.invoke(io.clj:168) at clojure.java.io$fn__11568$G__11557__11575.invoke(io.clj:72) at clojure.java.io$reader.invokeStatic(io.clj:105) at clojure.java.io$reader.doInvoke(io.clj:89) at clojure.lang.RestFn.invoke(RestFn.java:413) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.RestFn.applyTo(RestFn.java:135) at clojure.core$apply.invokeStatic(core.clj:669) at clojure.core$slurp.invokeStatic(core.clj:7089) at clojure.core$slurp.doInvoke(core.clj:7089) at clojure.lang.RestFn.invoke(RestFn.java:413) at sc.vodafone.website.pages.may22.templates$render.invokeStatic(templates.clj:10) at sc.vodafone.website.pages.may22.templates$render.invoke(templates.clj:6) at sc.vodafone.website.nav$render.invokeStatic(nav.clj:118) at sc.vodafone.website.nav$render.invoke(nav.clj:106) at sc.vodafone.website.html_export$nav_page.invokeStatic(html_export.clj:29) at sc.vodafone.website.html_export$nav_page.invoke(html_export.clj:25) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website.html_export$http_root.invokeStatic(html_export.clj:52) at sc.vodafone.website.html_export$http_root.invoke(html_export.clj:50) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website$root.invokeStatic(website.clj:656) at sc.vodafone.website$root.invoke(website.clj:650) at shadow.server.http.core$do_request.invokeStatic(core.clj:840) at shadow.server.http.core$do_request.invoke(core.clj:836) at shadow.server.http.core$do_ring.invokeStatic(core.clj:858) at shadow.server.http.core$do_ring.invoke(core.clj:844) at sc.vodafone.system$get_ring_handler$fn__28838.invoke(system.clj:420) at ring.middleware.file$wrap_file$fn__28579.invoke(file.clj:50) at ring.middleware.content_type$wrap_content_type$fn__28613.invoke(content_type.clj:34) at org.httpkit.server.HttpHandler.run(RingHandler.java:91) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) at java.base/java.lang.Thread.run(Thread.java:1583)
Aktivierungsportal ausgefalle n
Der_Name
Seit 6 Wochen hat Vodafone das Aktivierungsportal deaktiviert,  ich gehe davon aus, weil die ihre eigenen Boxen vermieten wollen, diese Boxen sind aber leider  Müll.  Habe angerufen,  man sagte, das die keine eigenen Boxen aktivieren.  Ich habe das jetzt an die Verbraucherzentrale und an die Bundennetzargentur gemeldet,  da es hier verhindert wird, die Freie Box Freiheit zu gewährleisten.
Bundesland hast du noch nicht genannt
poste einen Screenshot vom Online-Monitor der Fritzbox
PS:  was willst du mit vier 6591 ?
13 Antworten 13
andreasabaad
Das Aktivierungsportal wurde mit Gewissheit nicht deaktiviert, um eigene Fritzboxen vermieten zu können. Genauso sind die mehrvoder weniger Müll wie deine eigene. Hast du evt. eigene DNS Server eingerichtet? Wenn ja, lösche diese einfach.
RobertP
welches Bundesland?
wie lautet die Artikelnummer der Fritzbox?
2000 2857,  es ist eine Freie Box.
Ich habe 4 Boxen 2000 2857 hier, immer der gleiche Fehler. Aktivierungsportal nicht verfügbar,  schon komisch?
Der_Name
Hab es hin bekommen,  über einen Umweg. Also kann man hier dicht machen.
was denn für ein Umweg?
Die Aktivierung über die Box, im Menü. Deshalb eine Freie Box, dann kann man das Expertenmenü öffnen. Ich sag ja, es geht nichts über eine Freie Box, da geht viel mehr.
andreasabaad
Ausgeschlossen! Über die Oberfläche kann keine Box freigeschaltet werden!
