am 05.10.2025 20:59
Ich weiss, Vodafone will bei IPv6 Vorreiter sein, aber kein Grund bei IPv4 jetzt die 33.6k Modem Experience aus den 90ern zu liefern:
C:\Windows\System32>tracert -4 www.heise.de
Tracing route to www.heise.de [193.99.144.85]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms fritz.box [192.168.178.1]
2 221 ms 203 ms 198 ms ipservice-092-219-224-207.092.219.pools.vodafone-ip.de [92.219.224.207]
3 186 ms 183 ms 185 ms 92.79.214.42
4 165 ms 134 ms 133 ms 145.254.2.209
5 207 ms 194 ms 191 ms ipv4.de-cix.fra.de.as12306.plusline.net [80.81.192.132]
6 184 ms 171 ms 160 ms 82.98.102.7
7 250 ms 223 ms 213 ms 212.19.61.13
8 286 ms 287 ms * www.heise.de [193.99.144.85]
9 269 ms 282 ms 323 ms www.heise.de [193.99.144.85]
Trace complete.
C:\Windows\System32>tracert -6 www.heise.de
Tracing route to www.heise.de [2a02:2e0:3fe:1001:7777:772e:2:85]
1 1 ms 1 ms 1 ms fritz.box [2a00:1f:9180:e501:36e1:a9ff:feb1:36e9]
2 * * * Request timed out.
3 10 ms 8 ms 8 ms 2a00::150:0:7
4 9 ms 8 ms 8 ms 2a00::5fff:0:5d07:5a10:1
5 * * * Request timed out.
6 * * * Request timed out.
7 * 21 ms * be100.c350.f.de.plusline.net [2001:7f8::3012:0:2]
8 21 ms * 21 ms 2a02:2e0:11:16::1
9 19 ms * 20 ms 2a02:2e0:10:21::2
10 18 ms 18 ms 17 ms 2a02:2e0:3fe:0:c::1
11 21 ms 21 ms 21 ms www.heise.de [2a02:2e0:3fe:1001:7777:772e:2:85]
Trace complete.
C:\Windows\System32>ping -4 www.heise.de
Pinging www.heise.de [193.99.144.85] with 32 bytes of data:
Reply from 193.99.144.85: bytes=32 time=167ms TTL=248
Reply from 193.99.144.85: bytes=32 time=165ms TTL=248
Reply from 193.99.144.85: bytes=32 time=201ms TTL=248
Reply from 193.99.144.85: bytes=32 time=162ms TTL=248
Ping statistics for 193.99.144.85:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 201ms, Average = 173ms
C:\Windows\System32>ping -6 www.heise.de
Pinging www.heise.de [2a02:2e0:3fe:1001:7777:772e:2:85] with 32 bytes of data:
Reply from 2a02:2e0:3fe:1001:7777:772e:2:85: time=21ms
Reply from 2a02:2e0:3fe:1001:7777:772e:2:85: time=22ms
Reply from 2a02:2e0:3fe:1001:7777:772e:2:85: time=25ms
Ping statistics for 2a02:2e0:3fe:1001:7777:772e:2:85:
Minimum = 21ms, Maximum = 25ms, Average = 22ms
am 05.10.2025 22:02
ich nehme an dein Anschluss läuft auf DS Lite
das Problem sind die oft lahmen, bzw. überlasteten AFTR Gateways
05.10.2025 22:13 - bearbeitet 05.10.2025 22:15
Und nein, Vodafone wird daran nichts ändern - und das stellt auch keine Beeinträchtigung des Anschlusses dar.
Und "bei IPv6 Vorreiter" ist völliger Blödsinn -- IPv6 im Kabelnetz gibt's seit fast 15 Jahren, DS-Lite ist seit über 11 Jahren Standard für Privatkunden -- das Problem sind eher die Dienste, die weiterhin der Meinung sind, nur IPv4 fahren zu müssen, obwohl IPv6 seit über 25 Jahren besteht und seit 2011(!) alle IPv4-Adressblöcke weltweit vergeben sind.
am 05.10.2025 22:45
Also ich finde das stellt eine Einschränkung dar und sollte so nicht bleiben. Wenn es tatsächlich an den AFTR liegt würde ich z.B. Vodafone empfehlen, diese für ihre Kundenanzahl ausreichend zu dimensionieren. So könnten die Kunden von Vodafone sämtliche Dienste im Internet problemfrei nutzen.
Der Standpunkt alle anderen sind schuld, weil diese nicht IPv6 verwenden, hat schon etwas von Geisterfahrer auf der Datenautobahn.
am 06.10.2025 00:49
Vodafone könnte die AFTR längst viel kleiner dimensionieren, wenn entsprechende Dienste IPv6 -UND- IPv4 anbieten würden und nicht nur auf IPv4 setzen würden. Bei den meisten modernen Betriebssystemen ist nämlich die Nutzung von IPv6 gegenüber IPv4 bevorzugt und es findet lediglich ein Fallback auf IPv4 statt, wenn kein IPv6 möglich ist.
Nein, das Problem der -mittlerweile ausgegangenen- IPv4-Adressen war schon Anfang der 1990er abzusehen und wurde mit der Verabschiedung von IPv6 als Standard im Jahr 1998 gelöst...
Wenn es über 25 Jahre nach Einführung des Standards immer noch Dienste gibt, die meinen, diesen Standard ignorieren zu müssen, dann ist das mittlerweile deren Problem und nicht mehr das der ISP.
Schau dir einfach mal die Statistik von Google zum weltweiten Datentraffic an - dann verstehst du vielleicht, warum IPv6 keinesfalls mehr ein Nischenprodukt wie noch in den 2000ern war - sondern mittlerweile der Großteil des Traffics über IPv6 abgewickelt wird.
In Deutschland sind das schon 75%, Frankreich sogar 85% - selbst in den USA sind es 55% - insofern ist man mit IPv4-only eher ein Geisterfahrer, als wenn man seine Services mindestens mal per DualStack anbietet.
Und glaube nicht, dass es bei anderen ISP mit deren CGNAT-Gateways (wozu auch die AFTR-Gateways gehören) besser aussieht...
am 06.10.2025 07:23
Du scheinst mich nicht zu verstehen. Mein Anliegen hier ist nicht eine politisch geladene Grundsatzdiskussion über IPv6 zu führen. Du musst auch nicht davon ausgehen mir über IPv6 noch etwas beibringen zu müssen.
Fakt ist, es gibt noch Dienste die bevorzugt oder nur IPv4 verwenden. Als Vodafone Kunde kann ich diese Dienste im Moment zwischen 19 und 22 Uhr nicht ohne Einschränkungen nutzen. Vor 2-3 Wochen war der Zustand auch noch besser, es müssen also Änderungen auf Seiten von Vodafone stattgefunden haben. Woran das alles liegt müsste mich als Kunde eigentlich nicht interessieren. Das Problem ist Vodafone sicher auch schon bekannt, allerdings wurde es wohl als nicht wichtig eingestuft. Die vielen Posts hier im Forum sind ja ein Beleg dafür das ich nicht der Einzige bin.
