Wrong invoice amount in Kabel bill
Irene_z
Hi team,
I have informed your accounting department that the amount in the Kabel bill is wrong, unfortunately no feedback from your side is received. Please let me know how and who I can contact with regarding this issue?
thanks
MasterScorpion
What in the cable bill is wrong?
Here are your only options
Dein Kontakt zu Vodafone - Vodafone Community
kayakernightgow
Since you have already contacted them once, send a follow-up email or call the department directly. Be sure to include a reference number, invoice details, and a clear explanation of the discrepancy.
RileyJackson
If the accounting department hasn't responded, try reaching out to a direct contact in the billing department, as they may be more focused on customer-facing issues related to payments and errors.
____________________________________________________________________________________________________
Link entfernt
