Wifi connection problems
Airamaria
Hello! My wifi connection is not working since morning. On the modem the lights are on though.
I tried turning it off 4 times and nothing changed. I also tried to use the ethernet cable but still no connection.
I called Vodafone and they gave me a number. I called that number and they said write on the forum because they don't speak English well.
Could anyone please help me in English? What should I do?
Thank you
Hello Airamaria,
as the WiFi option is still booked I assume the router is defective. I would like to send a new one, are you okay with that? Shall I send the router to your home address?
Kind regards
17 Antworten 17
Valentina6
In Charlottenburg, Berlin, the same problem with wi-fi since 16.08.2021. It doesn't work at all. Can anyone say when the problem will be solved, please?
Martin59
Hello Airamaria,
I'll be happy to take a look at it. In which city and state do you live?
Best regards, Martin
Hello! Thank you so much for your reply! I'm in Braunschweig, Germany. Have a good day! Best regards
Martin59
Hello Airamaria.
then please send me the name of the contract holder, date of birth, full address and customer number via PN .
After that please leave a short info here.
Hello Airamaria,
I have just reset the cable router to factory settings. Please test if the connection works again now.
It's still not working
Hello Airamaria,
I couldn't find details for your WiFi on the router, what does the WiFi light on the router do? How about the settings in the router, is WiFi enabled? The login credentials are on the label on the device.
Kind regards
The lights are on, static like usual, including the wifi mode light.
If I go on the page 192.168.0.1 it says impossible to open it.
So what's next? Cannot a technician be sent to look in person?
