- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am 22.07.2022 00:00
Since recently my router started randomly (or not) shutting down wifi. Once shut down, it can only be restarted manually (via 192.169.0.1 or by pressing the button on the router). I think it started on one of the hot days this week (the temperature was above 36 degrees in the apartment), but the problem is that now it keeps doing that even when the temperature is back to normal. The router is not in a cramped space, it's just under the table, not facing a wall on any side.
"Band steering" is disabled in the settings, and I tried disabling 5GHz mode altogether, but it did it again after that.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 10.08.2022 14:51
then you new Fritzbox isn't activated
when does your new contract starts?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 10.08.2022 14:58
i guess you are right. it's 19.8, according to this line (right?)
Red Internet & Phone 1000 Cable U Expected activation: 08/19/2022
also, the settings page shows this cable information (1mbs downstream)
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 11.08.2022 10:21
Hi rumpelstiltskin,
it will be activated on that date. You can use your old equipment till then.
Kind regards
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
23.08.2022 12:00 - bearbeitet 23.08.2022 12:17
ok it's working with the fritz router since the 19th, but there's now a new small problem. occasionally it loses internet connection for like 5 seconds or so. i don't think it's the cable, since i tried several cables, even bought a new cat8 one, the physical connection is solid (it "snaps"), and no physical disturbance happens when it disconnects.
there are these events in the system log: e1rexpress: Intel(R) I211 Gigabit Network Connection Network link is disconnected.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 23.08.2022 12:44
seems like some people on the internet also have this e1rexpress problem (i have aorus x570 mb). so far there doesn't seem to ba a clear solution on the forums. i guess in my case it was triggered by switching to higher speed, or some other router-network adapter interplay. i tried downloading newer i211 drivers directly from intel's site; let's see if it helps.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 24.08.2022 13:31
Hello rumpelstiltskin,
Has the new Intel driver brought any improvement with the connection?
Regards
Steffi
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 24.08.2022 13:52
i also disabled "energy efficient ethernet" in the driver's settings (following an advice from the internet), and so far i haven't seen the problem anymore, but it's been less than a day in this configuration, so it's probably too early to declare it a success.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 25.08.2022 07:10
Then feel free to test for a while longer and then write whether it stays that way.
Many greetings Jana
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 25.08.2022 19:18
ok after some downloading and watching streams i still haven't got it, so hopefully it's fixed
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 29.08.2022 07:56
Hi @rumpelstiltskin,
that sounds good, thanks for the feedback 🙂 Gonna close this thread then.
Regards
- « Vorherige
- 1
- 2
- Nächste »
