- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am 13.10.2021 09:14
hello
I just took a new contract and I started my router yesterday. but I can't find the bridge mode option in the customer portal as before. I looked in the forum and found out the same problem. Apparently, for the new wifi6 router, this option should be in the router's settings not in the customer portal. But I can't find it either in basic and expert mode.
If any expert can shed some light on this, I would be grateful and so many other customers also.
BR
Roni
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 13.10.2021 13:29
bridge mode on cable router is a service that needs to be set by vodafone. There was the possibility to set this at "Einstellungen" at myKabel or the like. But this option disappeared a short time ago. You have to call the hotline.
Best Regards,
Ralf
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 13.10.2021 16:50
thanks. I called the hotline and the guy turned on the bridge mode for me. Unfortunately, as I understood, if I want to turn off bridge mode, I need to call them again. I wish it was in the customer portal, so I can do this by myself. Although I won't need to turn it off (i hope).
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 16.10.2021 10:39
Hello arifroni,
unfortunately there is an error with the bridge mode in the customer portal. Hopefully it will get fixed soon so you can enable and disable the bridge mode on your own again.
Kind regards
